You can view the running configuration using the show command.
  1. Enter Privileged EXEC mode:
    enable
  2. View the running configuration:
    show running-config
Switch:1#show running-config
Preparing to Display Configuration...
# Fri May 26 20:14:23 2023 UTC
# box type             : VSP-7400-48Y-8C
# software version     : 8.10.0.0
# cli mode             : ECLI
#Card Info :
#  Slot 1 :
#       CardType          : 7400-48Y-8C
#       CardDescription   : 7400-48Y-8C
#       CardSerial#       : 1904Q-20022
#       CardPart#         : VSP7400-48Y-8C
#       CardAssemblyDate  : 20190124
#       CardHWRevision    : 0
#       CardHWConfig      :
#       AdminStatus       : up
#       OperStatus        : up
#!end
config terminal
# BOOT CONFIGURATION
boot config flags ftpd
boot config flags ipv6-egress-filter
boot config flags sshd
boot config flags telnetd
boot config flags tftpd
boot config flags vrf-scaling
#boot config sio console baud 115200 1
# end boot flags
